Using TA as work bench very bad lol.🤣 Hope to start work on it soon. Did the oil on supercharger engine oil check other fluids and greased all the nipples 14 of them
Well that went better than expected so far, used camera function on autel scan tool no old gasket left on head or manifold so that good the bolts are in rough shape some of the threads not right cleaned the far right one up re died it 3/8 curse thread with 7/17 head for spanner, then on wire brush on bench grinder , do i change over to new stud and nut in stead of bolts???? can be seen been blowing for some time black sooted up gasket and bolt threads didnt use ramp as if job went pear shaped the heads would of needed to come of didnt want to tie the ramp up so 2 rear bolts access through wheel arch ,
Did you get to use your new 'heating up bolts' tool?
No I didn't order one in the end 1st bolt easy 2nd tight 3rd tight 4th very tight and pig to get to 5th easy. Wonder wat other side will be like??? Very suprised to be honest looking at how rusty they were
Maybe the last person that put them in put some anti seize stuff on the threads? Fingers crossed the other side is as easy.
Put TA on the ramp to check underneath from doing gasket. And to grease all the nipples. Found damper ( shock) loose nut rusted on used heat to remove it took shock of car to rethread it and new nyloc shock felt a bit week sod I ordered new pair so thought I would take the other one of ready that was a pain this didn't feel that good and both very rusty so good job I did order. So did a bit of tidy up of washer pump. Hose and battery cables use my rivet nut set and rubber p clips
Went take car out of garage ready for Sunday event at Shrewsbury after cleaning it on Friday. Well that didn't go to plan started car let it warm up reversed out of garage turn car off did a few things inside b4 going went back to car wouldn't start totally dead nothing feking great all I need tried jump pack nothing fek leave it had to take mustang and look wen I get home. Suppected starter motor all day in my mind running through what it might be. Jacked car up cable bolt on starter very loose no not the nut the bolt that goes into starter motor. ( Dan's going yo post video I sent him) but now car on drive and not on ramp. Dad and not got the strength to push car onto ramp so we towed car back up drive as drive on an incline removed rope from audi and free rolled it onto ramp result it worked. Ordered that night new starter motor from rockauto and removed old unit on Monday ready.
Thanks Dan. As we mention it was only 2 years ago the new one was fitted
Just turn up result. Ordered Sunday night great result
Finally had enough of doing temp repairs to exhaust system so went to Shrewsbury to get quote for new cat back system mine been on the car for 14 plus years done well. 1300 quid plus two days required and 4 hours of my time treverling back and forward. When my 3lt subaru from cat back cost me 600 quid and and 3 hours labour twin system from cat back. So looked at jegs and summit both prices not to bad went with summit racing in the end as brought some T shirts and extra exhaust hangers as kit didn't come with the ones I needed over axle everything else was in kit so for 760 all in with shipping tax and duty placed order here with in 4 days. Total time for me me to remove and fit was about 4.5 hours. Middle pipe you cut to fit length of your vechile. Treated myself to a new 1/2 impact wrench as well.
Are you happy with it? How's the sound?
Are you going to weld the rear hanger to the pipes or keep it adjustable with the clamp?
Happy with it so far sound is quieter than the old system but then it had holes in it. Yes those hangers by the axle have left until done proper test drive once that is all good will cut them back good point about welding might do that as well. Mate came round with his wife's new daily 1.2 fiesta with knackered exhaust looking on gsf and ecp 55 to 75 quid for exhaust system from cat back 1 peace how prices differ..
Question any body know what these two red plastic clips are for no instructions with the lower steering shaft replacement part.
My rag joint is badly warn so replacing it with the steering box I ordered a new steering coupler rag joint but it's the wrong one so had to reorder and you can get the lower half steering shaft complete with rag joint and new rubber dust cover but also in kit was these two red plastic clips don't know what they are for any help would bff e great.
Asked a trusty friend.
Short version first: those two little red plastic are shipping/assembly alignment locks for the rag‑joint (steering coupler) rubber disc. They are not installed on the car. They are only there to keep the rubber biscuit centred and compressed during shipping. You throw them away.
🔴 What the red plastic pieces are
The red pieces are shipping retainers.
Their only job is to:
- Keep the rubber disc compressed
- Keep the bolt pattern aligned
- Stop the rubber from deforming in the box
- Make assembly at the factory easier
They do not get installed on the car.
Once the coupler is bolted to the steering shaft and the gearbox, the rubber disc is clamped properly and the red pieces are no longer needed.
GM never used them originally — they’re just a modern aftermarket convenience.
Thanks dan bit strange as they were packed in there own bubble wrap. i have also contacted summit as well as they said i need to buy a coupler as well which i did as my shaft is round and the new style DD double d ( ooh matron) , my will be removed and new shaft fitted to my old DD shaft . once i have done this i can put new steering box in.
You can see the coupler here they wanted me to buy but don't need them .also have new top ball joints and tie rods, you can also see in picture the red plastic clips wrapped up on there own with the steering shaft
well i got a reply back from summit, they said speak to oer parts,
new lower steering shaft is in haven't used the red clips don't know what they are for? the OER website shower rag joints with or with out them and the steering shaft don't even show them but comes with them think i will send a message to them or firebird nation as used them is the past but they have got very expensive in there parts,
7
Also replaced top ball joint as well
Numpty I am damaged the new bail joint Doh. The steering shaft wasn't to bad to fit mine had a spring shim on the flat part of shaft could find any info. On this in any YouTube videos but was simple enough did have to adjust length once the steering box was fitted. Once I got all the steering sorted next will be new master cylinder have to bench bleed it 1st good job I had new unions as old ones are rusted on solid so far bound to break. Properly need to make up 2 new lines as well.
You have some much time and money. Its like you are retired but bringing in a good wage at the same time,
