Yep the picture with the rockauto fridge magbet are the 3 flexi hoses couldn't undo the brake union so just cut it all out fitted new hoses new lines new unions new valve new cylinder new clip in some areas done bleeds tried brakes this morning only moving forward backwards on ramp stops but still little bit soft so another bleeding session excuses the pun lol. As complete hose system changed not supriced there might still be air in system.
You might find more air after a drive, vibrations could move some bubbles.
Test drive after bleeding brakes again and doing oil change.
Went Realy well on 1st stop had leak think it was from mme over filling power steering and not allowing for cold hot reading bit of traffic as you will see but all in all a good drive out. So next tracking and mot like to do it every two years then that should just the leave the fuel gauge or sending unit to sort out at some point.
Looking gopd, nice weather for it and not too hot today.
Drained tank and removed fuel tank few of the hoses needed changing started to show signed of wear. Tested sending unit with meter this proved OK grounded out feed wired and the needle went back down once I had a good ground Earth . So reverse of today and refit and hope all is good??? Wasn't much fuel in tank so that wasn't to bad.
Pipes look a bit rotten coming out of the tank. Do you have plans to sort it?
New sender unit was fitted a few years back all the rubber hoses are being replaced metal pipes have cleaned up done the earth point on chassis this was very rusty and new connector crimped new eye let. So hopefully later today put tank back in. New fuel gauges not cheap so hoping has gauge moved when grounding circuits and sender unit test it's just refit job done?
had the brake light come on the dashboard reading the paperwork on the proportioning valve , needs bleeding and possible stuck internal valve or switch, bleed the brakes air the was aire in system after all this time but light stayed on release the little side nut and the piston came out and moved on its spring so put back in light still on it said open 1 bleed nipple on each axle fex i had just bleed them check switch ok unscrewed the switch from the top fek it took some pushing with my fingers once it moved i put back in all working so it was a stuck switch .
Well the fuel gauge isn't working so not happy the gauge in dash board reads 90 ohms with the shunt resistor across it fek these are not cheap cheaper buy new gauge if it was faulty the needle moves left and right full empty when you put meter on it or swop cables around cable from gauge and ground all good even tho I tested the flow switch in tank I have ordered another and testing this it's much more linear reading so hopefully changing it will sort problem??? Who got a bet on it doesn't lol 😂.
Should of put a brake disc over on order as one has rust hole but forgot about it with everything else going on DOH. Got half tank of fuel recon that will get me to MOT and back lol..😂
reading that reminds me i should find the fault in the p100 fuel gauge. its never worked correctly since i have owned it [about 5 years]
Past it's mot today
Nice it passed. Another year of trouble free motoring.
It's seems to be all the other cars you need to fix, Audi, Duster and Mustang.
Heated Rear Window Screen Heater - 12 Volt https://share.google/kzajJ5OquK8wn7Myt
Anybody fitted one of these or know of a good kit for the Ta
Went yo car show at weekend it was raining wen leaving was tempted to stay at home but day turned out ok but the rear screen misted up so was a right pain. OK the rear screen demisted is standard in all are cars now but back in the day lots of cars beaver had them. So tempted now to fit one if possible?
