On both mine the FPR is drivers side,,,I did suspect it would have the RED dash lights,,,very cool
Side by side in their house. If they can talk I wonder what they will talk about tonight.
Done more relay checking last night. I believe the relays are operating as they should. Still more checks to do before deciding on changing the pump.
I know what FWD WOULD SAY TO w56 HOPE I DOWN END UP THE SAME WAY AS swmnbo CAR DID
LOL :LOL:
PO15 in white has arrived along with the LSD additive. I should able to get the other oils from the local motorfactors.
Same as the one's i got off eBay,,Have you looked under the front seats yet for a build sheet ??
Checked under the passenger seat, no paperwork found. I hadn't checked the driver's seat.
Bonnet stays up without wood now. :)
Had a little tinker after the show today.
The seatbelt wouldn't retract
The spring had popped off. Removed it, was 2 x 13mm head bolts.
All back together and working great again now.
Emailed some parts places about parts, getting things together.
I do need to treat some of the rust, it's very light, but good to keep on top of it. So got some brushes. I'll clean up the axle and paint it in POR15 black.
Started to disconnect things to lower the rear axle, shocks disconnected, even one of the trailing arms so I could remove the calipers of this stuck one. I should get more time on it tomorrow.
Reason for lowering the axle is to get the fuel tank out. Also to take off any bits along the way to scrub up and treat.
Axle loer now, springs are out. Disconnected the brake line as it wasn't long enough for the axle to be on the floor.
Certainly some rusty parts to brush up and paint. I will probably just get new springs.
Busy . Put wheels back on roll axle out the way 👍.vice on the ground not bolted to bench yet DOH...
Exhaust was challenging, a grinder to the bolts done the trick. Looks like I could reuse the exhaust. I'll looks to clean it up and paint.
Tank has some rust.
Found the pump connector. Different on 85's and later, so was hard to find info. Glad I found it as would be concerning lowering the tank and it pulling a wire. But we are all good.
A wire brush to the tank. I think it can be preserved and painted. Not as bad as it originally looks.
