Purchased a 1983 Pontic Firebird TransAm
Fuel pipe ordered, 6mm, 8mm and 10mm. Measured my pipes with calipers, to verify before buying. Only need around 20cm of each to bride that gap between the metal pipes. Its how it was done standard, so I'm keeping it that way. The rubber pipes advertise E10 safe.
Also ordered some u-joints, different sizes. Some hold the exuast on, some for the anti roll bar, as would be nice to refresh those, the current ones look weak and could snap when I replace the rubbers. The rubbers have been ordered from rock auto, went for AC Delco ones original type of rubber, not poly. Aiming to keep the ride as it was when it was new from the factory.
Its getting there, most of the Rock auto parts will be arriving Friday, some Monday. I have a car show on Saturday its the Capel one, so I'll prep the 2000 T/A for that, also Southsea cruise on Sunday. Wont be getting a huge amount of time on the '83, Just doing it bit by bit.
Only think holding the axle on now it 1 lower control arm, the torque arm and the u-joints on the drive shaft. I think I will completly remove it, brake piping, the anti roll bar and wire brush it in the garden. Get this all looking new.
This restoration process will only be the rear half of the car for now, it seems a ood time to do it while soo many parts are removed for the tank removal. I'll do the front half another time, after an MOT. Perhaps it could be a winter job.
i used the same clamps as you been around for years , see these clamps at shows and on vehicle's not used them bit more money than the normal clamps stainless should last longer ??
Yeah they are good clamps. Used them on the air intake on the 4th gen. I got a few sizes at the time, so these are spare.
That u-bolts I ordered are just for exhaust hangers. Looks like the rest of the exhaust I can rejoin with 2 new bolts.
Nipped out for an hour to removed the tank straps and get the tank out, with a bit of wiggling it is now out.
Found a temporary place for the exhaust.
More goodies have arrived.
All rubber pipes I need also are here. Fuel pump filter sock coming tomorrow.
Done some painting over the weekend.
Also some heatshield bits too
Old fuel pump. No rubber pipe on top. Possible it's just corroded away.
new pump.
Pump fitted. New rubber pipe.
ETA on fire up of engine with jerry rig system ? Maybe this weekend?
Wanted to fire it up with the tank on the floor after changing the pump. Didn't want to get the tank in and discover some issue.
I brought new rubber pipes and got 1m long. This also ment I could run the tank on the floor to reach the pipes on the bosy.
Well happy with that.
Next if a bit of rust treatment before putting the tank back in place. Dosn't need much, its just surface rust, but as I have it all out, now is the time to restore it.
That's a great sound 👍
The area for the tank. All ready to pop it in
I did get the tank in. The. Had to take it out to get the straps in. Then it didn't want to go back in. After loads of juggling it was very annoying. Arms aching jack was a pain to get in place, needed to balance wood. Hopefully never need to do that again.
Put in new rubber pipes and started it up. Started it up, all runs still.
Get some new rust removal discs
Cleaned up this bar that goes above the panhard bar. Put the rust killing coating on it. If I get time tomorrow I'll probably get black paint on it.
how good are those discs?
Well not as good as their promotional videos. They done the job, not used any others, so can't give any comparison.
Started to clean up the axle with a wire brush.
Really needed to get the lower control arms out of th way. I have replacements, saves cleaning these up. I need to slean around the parts these connect to, so really had to come off anyway even if I wasn't replacing them.
Looking up the bracked the lower control arm connects to it neds attention. Nothing worrying yet, but left would not be nice.
I will get this cleaned up too.
Both off. something for the scrap man. New ones at the same length. They didn't list them for a 1983 Firebird, but I know they are the same as my 2000.
Its all progress. More tomorrow.
progress as you say
The u-clamps that hold on the anti roll bar bushes appeared to be coming off okay however got to a point where the nut just wouldn't move anymore.
Well our came through angle grinder after checking my new ones will do the job.
Also removed other stuff from the axle like the clamp that holds the metal pipe as it transitions to flexible.
Stopping for something to eat then I'll wire brush bits.
It's a lot of work, but then I know the rear end won't need attention for quite a while.
