i plan to go to Hayling tomorrow[ got a cold so feeling a bit rough at the minute ]. i got one advisiory ball joint in end of pitman arm, its part of the arm so far i can only find arms for manual steering cars and i have power steering
hope ranchero is wrong that the new self bleed pump not damaged master cylinder
it was only the resovior that came out no harm done execpt the mess, caused by the rubber going very soft. i used a zip tie to ensure it could not happen again. i now use the type that sucks the fluid through. snag. it works will but it will suck air past the thread of the blead screw
Ordered some more oil.
It's not April the 1st is it??????? How much
Lol, slightly cheaper buying it 20lites at a time. It dosn't go off and will last many years of oil changes.
Got hold of a spare set of rear lights some time back from a chap in Southampton that converted to euro lights when it came in.
Gave them a good polish. Came up like new.
New at the bottom, old at the top. You can see my old crack repair that I done with epoxy resin. Pretty good job but crack was still visible.
Such a nice shine on it.
All fitted now, replaced both sides
Not American, but the ST got a little upgrade. The brake light in the spoiler is white, I think that's odd especially as the Fiesta's is red. So I decided to get a smoked rear light. It looks so much better!!
Well done looks smoking hot
Went to move audi yesterday bloody dash board lite saying blown light rear light bulb blown nice and white lucky had spares in garage
Started on dad's car front discs and pads done got drop links and bump stop covers still to do with fuel filter and oil change as well fuel filter is 3 types so taking of then take to motor factors why do car manufactures make it such a pain on. Parts?
If wondering why there is a blow touch on ramp had to heat up the counter sunk resting screws that hold the disc to hub as these were in there tight if you round the heads of in a world of pain trying to remove then retap the threads and new counter sunk screws.
Those old disks look a bit tired. New ones looking good. An easy job for a change?
Was running on 7 on the Southsea cruise was a little lumpy.
Plugged in the laptop through next day, ran up the car and disabled the injectors 1 by 1. Disabling #3, it didn't effect the RPM. So looks to be #3.
Changed the plug today. Made no difference. Goty temperature thingy out. Can see it's #5 not functioning.
After work around 5.15pm whipped out #5.
Seems the wireless function wasn't working. Inserted another that was more solid.
All seems good now.
Collected new plugs today. Prices must have gone up since last time. I was thinking £64.
Got a spare plug in there for now, still misfire but only under load. So thinking the bad plug has damaged the lead it coil pack. Single coil pack in summit is $160 plus shipping/taxes just for 1.
Well the lead was certainly duff. Couldn't tell under the sleeve but with sleeve removed you can see the issue.
Opps snapped wheel bolt unable to get broken part out so new hub and knuckle as unable to get just hub off. Rust keeps fighting me
