Everything under the car has been cleaned up ready to spray on metal prep. I'll do that tomorrow as you need to keep it wet for 40mins before washing. Then wait for that to dry before putting on the rust protection. A full evening should do the trick.
I'll get these small parts below cleaned up too. I have new rubber bushes but need to reuse the metal clamps.
Bit more done👍. Better stock up on cutting discs at this rate lol......
See sponge bob has been helping you 👍
Used my new cleaning discs to clean up these bracked that hold on the anti-roll bar.
Lets get this metal prep on the axle and everywhere else under here.
Good coule of coatings, eeing it wet for over 30mins
Not to forget about the underside of the tank.
All these bits coated too.
I had to rinse off with water afterwards. I used the spray gun part of the compressor with water. This was awesome. Loads of water everywhere.
Leaving the dehumidifier on to dry it out. The floor dosn't look wet in the above photo and this was after all the rinsing off.
All ready for a coat of this. Perhaps tommorow evening.
Get on well with it👍👍👍 you enjoying it
Yeah enjoying it. Doing it but by bit, no rush. It may be taking a long time and no one going to see it, but I know it's treated for many years to come.
Painted all I wanted ot paint.
Should be dry tomorrow. Ready to assemble it all.
Panhard bar on, and other beam above it. Shocks joined at that top. Next it thelower control arms.
The lower control arms. Once on I'll slide in the springs before doing that lower shock attachment.
A lot of it together now.
Guess what numptie forgot this part.
Some bits will need to be removed to lower the axle and thread it in.
Ill get back on it tomorrow.
It's looking good you need a JD to relax now lol.... But bet swmnbo has a few jobs for you???????
Anti rolls bar on there now, now bolts etc. all suspension stuff done now.
Next is the brakes. It's wound in as far as it can go. Can't get the disc in-between. Needs about 1 more mm. Will research more and tinker more tomorrow.
Did start it up again.
Why dose that pad look concave in pic also disnt look. Like it's located correctly in caliper you not got new pads to go in?
Pads look fine. And no gaps behind them when located. After chatting to AI it said once the cylinder is fully refracted it's flush with the caliper. It showed me a winding in tool. So brought this arriving this morning. Hopefully it will give me that extra mm of clearance.
Fou d a very good video of a strip down the the calipers. Wow, how many parts in there. I'm not planning on stripping mine, but it's great to understands how the parking brake works with the cylinder.
remember they is a left hand thread and right hand thread that's why there is two in there if you were wondering? like ranchero use mine a lot .
i don't use the left hand one much. mine's a bit rusty now as a result of brake fluid and working in the rain
I had a floppy wing mirror, the whole housing would wobble. Today i made a video of dissasembling the door card and reassembling to tightend up the nuts. Thought the video would be useful for others as its always nice to know what you are going to come accross before you start the job.
I wont be as popular as Ranchero though.
