No excavating of the pit area yet.Looking good
Have they started excavating for the pit yet? It's difficult to see but it doesn't look like it in that picture.
Got it. I guess that's the most logical way to do it really. I bet the pit hole won't take long with the mini digger once the main floor is laid and set. I expect you'll be needing to get on with wiring up the pit electrics pretty soon?No excavating of the pit area yet.
Their plan is to concrete fill the whole floor(excluding the pit area) then dig out the pit hole.
The concern is if the pit was excavated and the concrete fill had a misshap there would be a hole filled with concrete. The pit area has been boarded off to create the shape needed for the pit.
I did say in post #148 that it's 16mm2 SWA. I brought the cable you recommended. This will be about 2ft deep to the garage, even by the door where its under concrete. Also I'm not connecting the two ends. If Darren dosn't come down I'll use the same electrictian that commissioned the previous electrical changes to the house.16mm T, E the CPC is under sized for a submain for a garage thought you were using swa from house to garage. The earthing requirements state in reg bs7671 earthing same size or one size under supply cable size using 3 core swa meats this requirement you will need to run a separate a separate earth cable with the twin and earth cable..
Yep that can be arranged.Us workers got the bacon eggs sandwiches going and 2nd fixed all the electrics my electrical supervisor popped over yesterday as needed some parts out of van saw my garage very jealous apart from he is a biker not a car man.
