ford gearbox 4R70W
renchero
this is not the original box its about 23 years newer than the Ranchero. i bought it a few years ago supposedly with an
taken it apart and not put all bits back in. it was rebuilt and i was pleased with the result, especially the extra gear.
recently the box had developed a 1-2 shift fault. i read the codes witch said "slip" not the fault i was looking and the fluid
had some muck in it.
box out time
pictures as required
You been busy so what you found so far???? Auto box if its a auto?
the valve, left of last picture is badly worn. this is what controls the 1-2 shift. i have an oversize one coming from Sonnax. this should cure that problem. the slip problem, i am still working on that.
How you getting on with gearbox doing any other jobs to car while it's in bits???? Sorry my ramp tired up now it's got a mopar on it...
was hoping to start the rebuild at the weekend but the parts did not get delivered until today
This should be good with pics and discripition and one hell of a jigsaw puzzle
I've seen videos of youtube of them dissasemblying and reassembling an auto box. I would never attemprt something like that myself. Soo many parts that look simular and need to be int he right order.
Good luck getting it back in and driving. That will feel like such an achievement.
i have never let not knowing what i am doing from stopping me doing something
i have now found what is slipping, its the direct clutch. i an going to upgrade the seals
the one on the left is the original. some say it can leak across the joint. it only there to make it easy to fit. the one on the right is solid plus its a bit wider but special tool is needed to fit it. so i made one
left side to stretch it on and the sleeve to shrink back
all that just to do this. i now need to get a new drum that the slipping clutch pack sits in as its badly worn
You redneck you enjoying working on the gearbox think we all enjoying this thread keep the updates and pics coming
just ordered a new direct drum. so its all on hold till that arrives, they say on the 19th. dam good service that i think. its a Sonnax part, a bit spendy but so is rebuilding this transmission and i don't want to do it again
While you're waiting for the drum, it's worth checking the direct clutch piston for cracks or scoring and air-testing the new pack before final assembly. Also clean the cooler and lines—if the fluid had muck in it, debris can lodge in the valve body and cause or mimic shift problems. Your seal stretcher/shrinker setup sounds like a neat workaround.
thanks Rachel, i might get a new cooler as i have been using this one for 35 years. its been on 3 vehicles. the drum is a Sonnax part that comes with a new piston
i now have some nice new shiny bits to play with. and the old worn bits i am replacing. just need to make a seal fitting tool as i am not paying £85 to buy a set of seal fitting tools to use one only once.
Some sort of steam punk made item with all the old parts my be??? Xnas gift for someone
good idea. however i am not very arty, i could stick it together but would need someone else to design it
