should it have vented discs on the back?
Good question and I wondered that myself last night.
Looking up rear discs on Rockauto they do seem to be vented. It does give me a thickness of 26mn so I can check that with what I have, perhaps wrong ones are in there.
Done a few emergency stops on the drive way. Checked for any brake leaks. We are good to go.
A little drive around the block at low speed. Was some noises like pads rubbing on the disks. That may just clear with driving. There was some smoke under the bonnet, like oil seeping out of the rocker cover(not sure).
Darren recommnended some Stop leak to revice old gaskets. https://rislone.com/international/wales/
wouldn't be surprised if rocker cover gaskets need to be replaced as been siting for so long . the link above for the seal restore wont do rocker cover gaskets but will help will valve stem steals other brands of that stuff are available,
do you know if rocker cover gaskets are rubber cork or silicone type???
Created a little Youtube video.
Removed the old filter.
Replaced with a new one from Rockauto.
Oil difficult to fill up as soon much stuff around the hole. This is after removing some stuff already.
I have this funnel but the end it around 38mm need 28mm to get it in the oil filler hole.
Whipped up a design for a 28mm funnel. Started printing already
The scraping noise from the wheels verified to be rusty disks, can cause it by rotating by hand. Bearings are good. The rust will wear off with driving. Only part of the disk has rust now. So it is getting better.
Filled it up with some new antifreeze recommended by guys in the car club. It's pre mixed. Radiator full and bottom pipe full. Need to run it up, but first need to put oil in. New funnel ready at midnight.
Oh greased my nipples too. All 7 of them at the front.
how are you going to get both of them to the end of season show?
That will be the difficult one.
Sarah doing the great south run too.
Easy if one car had a tow bar and had a trailer. Now that would be a site to see pontiac towing a pontiac......
Played on the playstation this morning before the show.
Driving my pace car online before driving it in real life.
Put together a Youtube video for the funnel creation. A longer video to come.
Car seems to be going well. /took it to Fareham yesterday. Certainly got some attention.
Found a source for decals. I dont have the door decals or the front and back windows. I would like to get the car back to how it originally was. Many models had these bowling ball wheels. However looking on the original order for mine it has the wheels it was supplied with.
I'll wait to see how my job pans out then I'll look into getting the decals.
https://phoenixgraphix.com/transam/1983pc.php
I only have 3 of these center caps, and of those many of the clips have broke.
So drew them up in CAD and printed one out as a test fit. Worked pretty good, some minor mods to do.
I will print through finals in black ABS. I have seen photos of the pace car with black centers. I believe black is correct. But if not I could spray silver like the ones on there have been spray painted.
For the center emblem I found these on eBay. Various sizes. https://ebay.io/m/FC4bb8. Looks to be made to order from Germany.
That looks very good,,,only thing i would consider is heat from the wheel as i have lost some of these over the years. Would appear now that the restoration firms have added metal retainers in the cap....as per picture
Thanks. I really didn't know new replacements were available. Now I do. This does give me another option.
Created a short video on YouTube,already have over 1000 view in under 2 days.
Not sure if people are sharing it about.
Yesterday whipped up a video for the 2000.
Not sure if it is just randomly appearing for it to be viewed or someone searching.
It will be interesting to see what gets the most views.
I guess Thumbnail and title play a part...
