Got skimmed flywheel back yesterday just waiting on parts from usa then can plan on putting back together, as can be seen clutch is shot and flywheel and plate badly burnt and had knasty notches in,
Dosn't look too bad, not over burnt. Good luck in getting it back together and running. It just takes time, well about 4 hours to swap my one out.
Are you putting if a higher performance one? they do feel a bit different but you get use to the biting point, i.e. on/off switch.
Yes took it off as a complete unit sitting in boot of mustang at the moment managed to get skimmed flywheel back on today and have now got new exedy 500 clutch waiting to go in . as it was delivery friday,
Yes will be back next year as want to bed in the new clutch. so will look out for v8uk pod dates for next year hopefully a few of the SR can tag along as well,,
Good job we had to remove charger to help with removal of gearbox as engine needed to be tilted back but this showed black soot marks around inlet manifold on supercharger to engine block so fitted new gaskets
new inlet gaskets,new exeddy clutch kit, new coolent new clutch fliud new bolts
and a happy test drive,
I should be up for it, I may be sorting my clutch thrust bearing in a week or so to get rid of that horrible noise. I will keep a look out for the dates too.
