Looking to upgrade brakes on the T/A
The brakes on the TA does have a high grade of pads, new drilled and slotted rotors, braided flexible lines. However the caliper is the same as origin. A single piston part.
With all these other upgrades, and also for looks. I now have 18 inch alloys, and the discs looks smaller.
I have some Willwood parts in the brake system. These brake discs would fill the 18inch wheel. I do need to check for clearence. This is just the front. 6 pistons to put in the larger brake pads. Giving far more braking control.
Rears have an upgrade path too. Not as much braking force on the rear, so these are only 4 piston.
You know me, always liking to upgrade bits.
Many colours to choose from, also options on writing colour
If I go with this. It's yellow calipers with black writing
Brake discs with calipers are hige. Needed to make sure I had enough room. I have 214mm from center to rim,but does taper towards the spoke of 10mm over a depth of 25mm. This means in places I have 5mm clearance from caliper to wheel.
(I really need to clean the inside of the wheels)
Its great they supply these diagrams,
Many colours can be chosen. Check out this awesome range. https://www.wilwood.com/Calipers/ColorSelect?id=28
I have heard back from Wilwood, they are working on a shiping quote. :)
The total for parts, the custom color, and the international bank transfer fee is $6374.08 USD. Shipping is quoted as $1610.95, plus $44.62 for insurance. The total comes to $8029.65.
They said the shipping is for two boxes two boxes about 14” x14” x 14” weighing 63lbs and 51lbs. They said I can shop around to shipping and get the shipper to collect. I tried FexEx economy at that was $1770
So cheapest shipping the one they mentioned at $1610.
$8029 total, Translates to £6014.30 plus VAT. Which is another £1200 on top. £7200, that's almost £2k per wheel.
