I am finally getting round to running the diagnostics on BM, set up the self diagnostics, and it produces a load of 2 and 3 digit codes, where can I find a list of what the codes mean?? Tried loads of places on the net, but nowhere seems to have them...
Beleave your bm is pre OBD 2 COMPLAINT ????? so thing the fault codes (your flashing lights) will be only generic type codes so any OBD 1 system should help you find you problems???. as OBD 2 SYSTEMS ARE GENERIC AND MORE PERSIFIC TO AN AREA OF FAULT ie mass air flow ,, lambo sensor coil packs and so on.
Hope this helps
dose not the hynes manel this OBD 1 fault codes (flashing light codes?)
