1964 Buick Wildcat Deluxe: Just completed 3180 miles around France and Spain. (Documented on FB) 17995 ONO. the details below. Fitted 1970 date coded 455, Edelbrock torker455 inlet manifold, new Edelbrock 750cfm carburettor, very rare 4 speed manual with Hurst shifter, approx 375 BHP / 510 lb/ft torque, 3.07 axle ratio (3.42 posi rear on its way and included). Saddle interior and switchgear in the sort of condition that supports the 35000 odd miles showing on the odometer. Owned now for about 2.5 years the Buick needed the timing sorted, new starter motor, the clutch replacing and converting to hydraulic release bearing. The brake system was overhauled as a precaution and the rear hub seals were replaced at the same time. Fresh matching tyres all round including spare, fresh dual flowmaster exhaust. New aluminium 4 core radiator and electric twin fans on a thermostatic control. Fresh window seals. 5 new Torque Thrust D"s including an unused one for the spare that"s still in the box, front sway bar drop links, 4 new shocks, a new rear sway bar fitted which has greatly improved stability and cornering. H4 halogen conversi n with 4 high & 4 low. New Heater core and control cables, new speaker in rear seat, dash and kick panels. New HEi Distributor, leads and plugs, oil and filter change. New thermostat and replaced the bling chrome housing with stock Cast item. (The chrome ones tend to leak.) removal of some "Walmart" trim down each side and making good. Passenger side mirror custom made to fit, new chrome door armrests. Various fettling and small jobs done. Drives and stops very well and is very reliable, gobbles up the miles (70 comes up at 2500 rpm) and is in daily use rain or shine and is remarkably economical. Being a manual I get 16/17 mpg without trying. A dry state car from New Mexico v a Nevada. Impco LPG system fitted, at 62p/litre this gives a 28/30 mpg cost equivalent. Also fitted is a "Flash Lube" valve saver kit to give added lubrication to valves. This can all be removed if necessary. Fancying a change, something interesting, Torino, Cougar, Thunderbird 61-65, Alfa GTV6/Spyder, Jaguar series 1 XJ6 or American 1950"s car or truck. Photos are a mixture of our current road trip and back in the UK. Sensible offers considered but don"t insult me. Everything works as it should. Leave your magnifying glass at home.<br />
<br />
Dubbed "Executive Hotrod" by CAR LIFE April "64. "A too-heavy right foot will produce a black strip anywhere on any surface without even trying." MOTOR TREND June "64.<br />
<br />
YouTube videos:<br />
<br />
Walk around: - details above<br />
<br />
Come for a drive: - details above<br />
<br />
<br />
<br />
New Parts:<br />
Starter motor<br />
Edelbrock 750cfm 4 barrel Carburettor <br />
Aluminium 4 Core Radiator with Electric fans<br />
Thermostatic control switch for fans<br />
Stock Delco horns <br />
11 inch Clutch and pressure plate<br />
Pilot bush<br />
HEi Distributor <br />
HT leads<br />
Spark plugs<br />
All new hoses <br />
Heater control valve<br />
Wilwood Clutch master cylinder with remote reservoir.<br />
Hydraulic release bearing and external bleed kit<br />
Hurst Comp. plus shifter<br />
Brake master cylinder<br />
Brake hoses and Brake wheel cylinders (all)<br />
Rear hub seals and Brake shoes<br />
Exhaust manifold gaskets<br />
Replaced missing 7 blade clutch cooling fan<br />
Repaired interior lights and replaced lenses<br />
Front dash speaker repair<br />
Stainless sill trim plates<br />
5 X Torque Thrust D wheels<br />
Quieter exhaust boxes<br />
Rear sway bar<br />
4 shock absorbers<br />
Front sway bar drop links<br />
Thermostat and housing<br />
Halogen H4 conversion <br />
All heater & blower control cables replaced and connected<br />
Glovebox light repaired<br />
Courtesy light switch repaired<br />
Ashtray light repaired and fitted<br />
Trunk light repaired<br />
Heater core replaced<br />
New Chrome armrests<br />
NOS passenger side mirror<br />
Full Impco LPG system fitted with 21 gal. tank<br />
Flash Lube valve saver kit<br />
OEM Windscreen washer bottle<br />
Front Seats restuffed<br />
Driver"s window regulator <br />
Plus many other small jobs and parts<br />
<br />
Original wheels and hubcaps included<br />
Miscellaneous spares included.<br />
Workshop manuals included<br />
Date written: 28-Aug-2019
Price: <td><strong>£17995 As stated
