wanted 12 bolt axle posi diff or clutch plates
supermotolew
New member
Hi all ! loving my new camino loads of power but my right wheel always brakes loose !
im guessing my diff clutch is worn out .
im looking for new plates / or diff .
also after a 72 chevelle or camino top dash and door cards
cheers !
Yep, may get lucky with just an oil change.
If not the clutches could be worn, there are kits you can get, and videos on youtube, but you may need special tools. I recently had trouble with my rear end (wasn't just wind either) took it to Hauser racing in Northants for a complete rebuild in the end.
might be a daft question, but have you had a look inside the axle could be its an open diff.
to be honest that's true ! im also just going from previous seller info !
my jack is bust but if anyone is at white dove show sunday that maybe has a jack in the boot maybe I can cock a wheel and check .
if its open im presuming a lsd carrier will still slip right in there ?
