The importance of Tyres
AmericanThunder
Super Moderator
When I bought the Challenger I noticed that the rear tyres were about 50% worn and were Pirelli Scorpion's, generally considered a premium tyre.
The front were virtually new Falken's.
I was happy with this as it meant I knew I could probably finish the year without worrying about them.
But yesterday was an eye opener. At about 9:30am with the roads still a little damp I exited a roundabout at about 1/3 throttle and spent the new few seconds saw'ing the wheel left and right as I tried to correct the over-steer from the rea tyres losing grip. Now normally this is fun, when you expect it and you've actually provoked it. But in this case it was just a case of the tyres being overpowered, far too easily, and with the traction control switched on. Made me more than a little wary.
And then shortly afterwards, as I was braking into another roundabout, the fronts showed me how little grip they had too, as they just plowed on in a straight line. Now, you can expect a certain amount of understeer with a big heavy engine up-front but considering how gently I was driving after experiencing the rears struggling for grip, it should not have happened.
So now, I am going to replace all four. I prefer to match tyres across the axles anyway so having different front to rear was not my idea of good balance.
I have also found out I can run a square setup (match the front to the rear size wise) without any interference so I plan to run 275/40 r20 all round and I'm looking at a set of Toyo Proxes T1Sport tyres.
Fortunately, they have good reviews and are reasonably priced.
Always good to have good rubber.
I have heard good things about Toyo, so good choice.
do the tpms need to be programmed to car or is it a plug and play system or can they be delted from ecu if you wanted?
Thats the same size tyres as mine and i think chris's as well,
got p zeros on rear
And I've looked at the p-zero's. They get good reviews for wet weather conditions but not so good in the dry and the longevity is good which suggest quite hard rubber.
As I would not let tyres go beyond 6 years old anyway, I'm happy for them to be shot within 18000 miles if they grip like a turd to a woolen blanket!
I've just put a pair of Dunlop sportmaxx on my rear and can't fault thm so far. If I could of found Avon zz3 I would of had a pair just to match the front which also seem to do the job. Mine are only 255/40/20 all round
K
Kim Adams
K
L
Luke Wilkinson
L
