my 9c1
Are that's better , is that water damage i can see on the fuse box?
Nice one, they look good.
Parking Brake Release Handle Assy is now fitted and working
Result, bet you are happy
[UPDATE]
i have bin trying to fix my head lamps all day new parts come today but did not Fix it
so my headlights low beam is not working Builbs are ok Got 1.New Dimmer switch but did not fix it then try my old cars headlight switch still no luck but useing a test light i cant get any power on the low beam wire off both from Dimmer switch and headlight switch
high mount brake light [FITTED NEW BULB HOLEDER]
Good luck with the lights. Are they sealed beam headlights?
dont no i need to fix it fast car has not mot now
yes its ok going to be fun grrrrrrr
Then assuming you have power to the switch, and you know the switch Is good then it must be open circuit or a direct short to ground between the switch and the lights.
Try running a length of wire between the switch and the lights.
Don't know what your electrical skills are like, so of course you may have already thought of or tried all this.
Wow certainly looks the part, can't believe how different it looks, you have been busy.
Looking good,
Starting to get stuff done on the car not been used much in year as of health problems doing a lot of rust right now
agree is rust can be a nightmare have to keep on top of it
Did I see an American day van on your drive ?
