Took the MAF
Added a clamp to protest the delicate wires.
Dremel cutting it up.
Starting to make it fit the oval.
Wired added to connect tot he black box.
Really happy with how it looks
Rubber seal added.
Sounds like a vacumm cleaner.
I'm very happy with it all though. Letting it run up to temprature while checking for leaks of fuel or water.
Took it out for a test drive, not putting it under any load apart from light throttle as I knew the fueling is way out. Data logged that drive. Looks like I need to remove 4% of fuel on light load, but add near on 8% on slightly more load. The car is learning. Its all within learning limits.
Certainly more tunning needed. The MAF sensor isn't connected, but I did test it on the desk and it producing variying waveforms depending on airflow.
Rubber seal added.
