Started the Corvette yesterday. Warmed up and ticked over at around 680 revs per minute. Took it out of drive and drove it to the end of the road, about 200 yards. Misfire started again. Just about enough power to take it around the block and get it up my sloping drive. I took off the bottom cover under the dash/steering column to test the ECM codes via ALDL, but couldn't find it. The car is not standard so possibly moved to another location.Perhaps I can see it if digital dash panel is removed. I am going to take out the fuel pump again(new one fitted recently) to fit a new fuel filter to it. I had to modify the old filter as it was damaged, by cutting it in half. Getting back to running the car, when started, all warning lights go off, but when misfire starts, yellow service engine soon came on. Also. digital dash average mpg dropped to 8 MPG and range also erratic .Will post again when in tank filter fitted and pump wiring renewed.Thanks to all showing interest in my problems.
