1965 Ford Mustang Coupe V8 Auto For Sale
15392tcac
1965 Ford Mustang Coupe 289 V8, 3 speed automatic Transmission.<br />
<br />
I purchased this car a year ago from America where it had a full bare metal respray along with new interior etc.<br />
Once in the UK I wasn"t completely happy with the car I had brought so ended up booking it in to The Mustang Workshop in Hampshire who specialise in classic Mustangs.<br />
<br />
The guys there basically went through the car from top to bottom replacing anything that was old and faulty, Along with upgrading many things to make the car start and drive as it should.<br />
<br />
The car is amazing, Starts on the button, Drives brilliantly and has lots of power.<br />
<br />
Below is a list of all the component"s that have been replaced and upgraded in October 2018, The car has recently had the racing stripes painted on, along with new chrome work, Wheels and tyres and brand new, I have probably only covered 200 miles since receiving the car.<br />
<br />
The car is pretty perfect for its age, I am reluctantly selling due to moving house.<br />
<br />
The car has never been driven in the wet and is always kept in a heated unit.<br />
<br />
I have all receipts for all of the below work along with pictures regarding restoration in California. <br />
<br />
I am open to sensible offers, Prices for these cars vary so much, It owes me over 40k<br />
<br />
TO FLUSH OUT COOLING SYSTEM<br />
TO INSTALL UP-GRADE 2 ROW ALLUMINIUM RADIATOR<br />
TO INSTALL SPAL ELECTRIC COOLING FAN<br />
TO INSTALL DAVIES CRAIG ELECTRONIC FAN CONTROLE<br />
TEMP GAUGE <br />
TO INVESTIGATE /REPAIR SELECTOR LAMP IN-OPP<br />
TO REPLACE DAMAGED TRANSMISSION COOLING LINES <br />
TO INSTALL UP-GRADE DUEL LINE POWER BRAKE BOOSTER <br />
TO REPLACE BURNT REAR FLEXI BRAKE HOSE <br />
TO INSTALL SUPPLIED HARMONIC BALANCER <br />
TO REPLACE DAMAGED ENGINE SUMP PAN <br />
TO INSTALL NEW HOLLEY 4 BARREL 600CFM CARBURETTOR<br />
TO INSTALL CORRECT STEEL FUEL PIPE FROM PUMP TO CARB <br />
TO INSTAL PETRONIX ELECTRONIX IGNITION UP-GRADE <br />
MAJOR SERVICE & FULL ENGINE TUNE <br />
TO INSTALL PATRIOT CERMAMIC COATED HEADERS <br />
TO INSTALL NEW S/STEEL PERFORMANCE EXHAUST SYSTEM <br />
TO INSTAL NEW MINI HIGH TORQUE STARTER MOTOR<br />
TO INSTALL FULL WINDSCREEN WASHER SYSTEM <br />
TO INSTALL MISSING UNDERDASH INTERIOR LIGHTS & Wiring <br />
DASH ILLUMINATION<br />
FUEL & TEMP GAUGES <br />
INDICATOR & STOP LIGHTS<br />
REAR NUMBER PLATE LIGHT <br />
NEW HORN <br />
TO INSTALL NEW BATTERY <br />
TO REMOVE EXISTING WORN OUT STEERING SYSTEM<br />
TO INSTALL NEW POWER RACK & PINION STEERING UP-GRADE <br />
TO REPLACE WORN P/SIDE UPPER BALL JOINT <br />
TO ADJUST PLAY IN D/SIDE FRONT WHEEL BEARING <br />
MINOR CORROSION AT BATTERY TRAY INNER WING SUPPORT<br />
TO REPLACE REAR AXLE BREATHER PIPE <br />
TO SECURE MONTE -CARLO BAR<br />
COOLING SYSTEM FLUSH <br />
RADIATOR ALLUMINIUM 2 ROW UP-GRADE <br />
SPAL 16" ELECTRIC COOLING FAN <br />
DAVIES CRIAG ELECTRONIC FAN CONTROLER <br />
TRANSMISSION COOLING LINE SET <br />
POWER BRAKE BOOSTER KIT <br />
BOOSTER VACUM HOOK UP KIT <br />
DOT4 BRAKE FLUID <br />
SUMP PAN GASKET KIT <br />
CLEANERS & SEALERS <br />
HOLLEY 600 CFM CARBURETTOR <br />
STEEL FUEL SUPPLY PIPE PUMP - CARB <br />
PETRONIX ELECTRONIC IGNITION KIT <br />
PETRONIX FLAME THROWER IGNITION COIL<br />
ENGINE OIL JOE GIBBS HR-1 HIGH ZINC <br />
OIL FILTER <br />
FUEL FILTER <br />
SPARK PLUGS <br />
PATRIOT CERRMAIC COATED HEADERS <br />
STAINLESS STEEL EXHUAST SYSTEM <br />
POWERTORQUE MINI HIGH TORQUE STARTER MOTOR <br />
STARTER HEAT SHEILD <br />
WINDSCREEN WASHER SYSTEM. HOSE KIT, PUMP, BOTTLE, JETS<br />
BATTERY <br />
POWER RACK & PINION STEERING KIT<br />
TIE ROD ENDS & TURN BUCKLES <br />
FLUIDS, BELTS, PULLEY <br />
SUSPENSION UPPER BALL JOINT<br />
METALWORK & WELDING CONSUMABLES <br />
AXLE BREATHER KIT <br />
MOTE -CARLO MOUNTING KIT<br />
TO REPLACE ALL EXTERIOR TRIM<br />
DOOR HANDLES <br />
DOOR MIRRORS <br />
DOOR LOCKS <br />
FRONT SCREEN TRIM KIT <br />
CLIP SET <br />
REAR SCREEN TRIM KIT <br />
CLIP SET <br />
REAR LIGHT BEZELS <br />
FRONT SIDE LAMP BEZELS<br />
NEW TOQUE THRUST WHEELS AND TYRES<br />
NEW INTERIOR, SEATS DASH, DOOR CARDS CARPETS HEAD LINER, STERING WHEEL, MATS, PARCEL SHELF, BOOT MATS ETC.<br />
CERMIC COATING TO PAINT WORK<br />
RACING STRIPES PAINTED IN LIGHT GREY<br />
NEW RETRO LOOKING STEREO (MODERN FEATURES)<br />
Date written: 11-Apr-2019
Price: <td><strong>£32500 Or near offer
