Working 3D printing the internal door relase area.
Scanned the original, the plastic around the screw hold is all broken. turned into a10mm hole, when It needs to be around 5mm.
Redrew the lot and adding a pattern along with the letters WS.6
Screw hole will take an 4mm allenkey bolt, sinking the head 4mm into the plastic.
Ready to print in the morning, drying out a roll if silament, which will be done by morning.
So over night I'll print out a draft one to check it fits.
Have you had any enquiries from other TA owners for parts ?
Yes, a front drivers side grille part.l for a 2nd gen TA. Too big, no original to scan. Although you can buy that part for a free hundred $, if I made that it wouldn't be much cheaper after you have factored in time.
It fits. This was a test print. The proper material was in that dryer overnight.
Final one sent to the printer. It will take around 6 hours to print. 167 grams. Approx £2 of meterial.
