Tyres - Strange Question
Rob63
Member
Hi - ok i have non standard tyre sizes fitted to my car how do i find out what pressures to run or shall i just guess
Mine are 275 wide. I run 28psi, as its whats specified in the door
I know you have changed your tyres, I dont know if there is a formula, but i guess weight will come into it too. Do your tyres wear evenly?
The wear looks good at present, 265/50 15 and 295/50 15 kerb weight 1440kg possibly similar to yours
I think around 28psi is good for normal driving.
When I do a g-tech run trying out my 0-100mph, I put my rear tyres down to20psi and soften the rear suspention and it really it increases grip dramatically
As your tyres are wider than mine it will work out a simular weight per inch on the tyre.
