Well as most of you know I have been having troubles with the bottom end of my engine, well the problem started at the top end.
The valve train dumped some shrapnel down the bottom end. Ground down into the oil. this is not good for bearings.
I have brought many parts to renew the top end, like cam, pushrods, lifters, rockers, gaskets and a more powerful cam.
Engine is out. Crank will probably have to be reground and larger bearings fitted. The other option is to change the crank/rods/pistons and make it a 383ci.
So I guess there is two options.
Stick with 346ci (5.7L) approx 500hp
Go with 383ci (6.3L) conversion to put out around 570+hp?
