The stock coil packs are very good and have been known to last over 200k miles. Its always nice to stick a fresh set of something on the vehicle. The LS engines use 8 coil packs.
Their blurb on it
MSD Ignition's Multiple Spark Coils (MSC) will fit in place of the stock GM LS coils and connect directly to the factory connectors. Once installed, you'll have the power and performance of higher energy sparks, crowned with MSD's multiple spark discharge. Increased spark energy and voltage, along with multiple spark capabilities, help improve the combustion process of the fuel mixture to create an efficient burn. This results in improved throttle response, smooth idle and quick starts, plus increased high rpm performance!
After doing some forum reading I found some rather nagative comments towards the product:-
Are the MSD coil packs any better than the factory LS1? Worth buying for L92 build? - LS1TECH - Camaro and Firebird Forum Discussion
From what I hear and have read, they are not worth the price, on any build. Plus I think they're ugly.
i bet if you didnt know if they were or wernt on the car you would never know. the stock coils are more than enough for the task IMO
We have taken out 2 set of MSD coils out of builds done at my sponsor's shop. Went back to stock coil packs. No problems. We have used LS1 coils in a Mustang, Toyota MR2 and numerous other turbo builds. All with no problems.
The MSD coils I have heard are used in FI applications. They help burn off extra fuel as they are multiple spark per singal.
I can't vouch if they will make your MPG go up or whatever because I went to an extremely cold plug at the same time for nitrous. I didn't loose any MPG though you think I would with a plug like that.
It seems the negative comments are more related to its not worth the money to swap out stock coils for MSD. however if my coils are getting old, and I want to stick in a fresh set, then I need to spend money anyway. GM ones are around $64 each, MSD are $80 ish each. I'll be buying a pack of 8, so a little money saved.
Do they look nice or what?
