CHevy 396 engine parts
Neil907
New member
HI
I have been helping my uncle clear out his garage, back in the early 70's he was involved in building engines for race powerboats and still has lots of parts from that period.
They are all for The turbojet 396 bigblock engine introduced in 1965, it is listed as coming in two guises the 325hp version and the 425hp version, I would assume these parts are for the 425hp but can not be sure.
I believe these parts will also fit the following vehicles but can not be sure
1965 1966 1967 1968 1969 1970 Chevrolet Impala Bel Air Biscayne Caprice Malibu Chevelle El Camino Monte Carlo Chevy II Nova Camaro and SS all models with 396 V8
1970 1971 Chevrolet all car models with 400 4 barrel V8
1972 Chevrolet all car models with 402 V8
1966-1969 Chevrolet all car models with 427 V8
1970 1971 1972 1973 1974 1975 Chevrolet all car models with 454 V8
1965-1974 Chevrolet Corvette models with 396 427 or 454 V8
1968 1969 1970 Chevrolet and GMC all Truck, Suburban and Blazer models with 396 V8
I have for sale the following, All new and unused but please bear in mind they all been sat on a shelf in a box 45 years.
Set of 8 Venolia forged pistons with gudgeon pins.
Set of 16 Crane enginnering Hi-performance chrome silicone valve springs.
bearing pt No 3876091 17 off std genuine GM
bearing pt No 3876085 2 off std genuine GM
bearing Pt No 3885380 8 off std genuine GM
bearing pt No 3876092 7 off +001" genuine GM
bearing pt No 3876093 7off +002" genuine GM
bearing pt No 3876094 8 off +010" genuine GM
bearing pt No 3876088 1 off +010" genuine GM
bearing Pt No 3885377 4 off +010" genuine GM
bearing pt No 3876095 16 off +020" genuine GM
bearing pt No 3876089 2 off +020" genuine GM
bearing Pt No 3885376 7 off +020" genuine GM
Perfect circle piston rings 1 set +030" some corosion but probably ok to use with a little cleaning.
Perfect circle piston rings 10 off pt No 40544 std-.010
Ex valve pt No 1#3860002 GR0.297 5 off genuine GM light corrosion but should clean up just fine.
Delco remy distributor cap
Delco Remy rotor arm
If you are interested in any or all of the above please let me know and I am happy to provide pictures.
Cheers Nei
Wow, loads of stuff there, hopefully it will be useful to some members and to take them off your hands. Thanks for posting!.
3K
2K
2K
S
Sean Carson
S
