T
Tom Barnard
Staying hydrated is vital to maintain concentration while driving, and water is better for you than coffee or sugary drinks. But mineral water in a plastic bottle costs at least £2, while the resulting rubbish is bad for the environment and clutters up your car.
A refillable water bottle can be used again and again, is easier to drink from and can be topped up at home or a public refill point. But which is the best?
There are thousands of water bottle designs on the market, so we concentrated on ones which are easily available either online or in supermarkets. They needed to be leakproof, fit snugly in a car’s cup-holder or door pocket, and be opened easily so you can sip while driving. Other points were given for price and ease of use.
It's not illegal for a driver to eat or drink while driving, but only do so when it is safe and won’t affect your concentration or control of the car.
If the police think it is causing a distraction or is impairing your ability to drive, you could receive a fixed penalty notice with a £100 fine and three penalty points on your licence.
Choose your water bottle carefully to make sure it will fit in your car and does everything you need. If size isn’t an issue, the Eurohike Spout Bottle is easy to handle, nicely made and good value. The Asda alternative doesn’t have the same quality but it’s half the price. Finally, the clever Brita bottle is ideal for those who don’t like the taste of tap water.
Asda 700ml Water Bottle
Contigo Purity Glass Water Bottle
Brita Fill & Go Active Water Filter Bottle
Best water bottles - header
Ion8 Leak Proof Slim Water Bottle
Mountain Warehouse 500ml Push Lid Bottle
Mountain Warehouse Infuser Bottle 600ml
Chilly's 500 bottle
Contigo Matterhorn bottle
Morrisons Green Straw Flip Bottle
The Chilly’s bottle has been around for a decade now and it’s a common sight in gym lockers, playgrounds and car cup-holders all over the world. It’s also a commonly copied design, so make sure that you’re buying an original if you want to be assured of the performance that we tested here.
At first it seems less user-friendly than some rivals. The neck is slightly too narrow to allow an average ice cube to be added, for example, and the lid isn’t tethered to the neck, so it could be easily lost if separated from the bottle. The Chilly's bottle really lives up to its name when it comes to insulation, with our icy water gaining just 7.6 degrees after 12 hours of being stored at a warm room temperature. It registered a still-refreshing 10.8 degree rise a further 12 hours later.
Buy now from Chilly’s
Chilly's 500 bottle
This bottle is big enough to see you through the longest journey. Pushing a button on the lid pops up a soft plastic spout, which is easy and comfortable to drink from on the move. It’s simple, no-nonsense and works well for drivers.
Our only word of caution is about the size. It’s 28cm high, so you may struggle to fit it into some car cup-holders without interfering with the controls; you might be better off putting it in a door pocket.
Buy now from Millets
Chilly's 500 bottle
As a basic bottle for keeping in the car, this Asda offering works well and is great value. It looks and feels a little cheap next to the winning Eurohike but, like our Best Buy, it holds 700ml and has a nozzle which pops up by pressing a release button.
It’s easy to use one-handed and is leak-free when the top is in place. Thanks to a carabiner-style clip, you can attach it easily to a bag when out of the car, too.
Buy now from Asda
Chilly's 500 bottle
This Brita bottle filters the water while you drink, making it taste noticeably better. However, the downside is the price: the bottle itself costs £16 and you have to pay £15 for three replacement filters, each of which will last for four weeks or 150 litres. That’s still a lot cheaper than bottled water, though.
The lid is easy enough to use with just one hand but there’s no straw, so you have to tilt your head back and squeeze the bottle to get a drink.
Buy now from Amazon
Chilly's 500 bottle
Contigo’s Matterhorn is the same height and width as the Chilly’s bottle, but has a less-tapered shoulder so holds more liquid than its similarly sized rivals. It also has a double cap, with only the upper twist top used as a cup. The second can be unscrewed to give a wider opening for cleaning or adding ice although we found it tricky to open, especially with wet hands. The top lid is held with a strap, so it’s hard to misplace and doubles as a handle.
These are great features, but the Matterhorn’s performance in the temperature test was disappointing. After 12 hours, the icy water had gained 11.1 degrees, making it warmer than the Chilly’s was at the 24 hour point. After a full day it measured 16.4 degrees – about the same as water straight from the tap.
Buy now from Amazon
Chilly's 500 bottle
If you are not keen on the taste plastic or metal bottles can add to your water, then the Contigo could be the answer. It uses glass and only a tiny amount of stainless steel in the lid. A sturdy rubber ‘bumper’ protects the glass from knocks.
It’s heavy though – the full bottle weighs more than a kilo – and the lid has to be unscrewed. No straw means you have to swig rather than suck, too, so this is best used when parked up.
Buy now from Amazon
Chilly's 500 bottle
This is the perfect bottle if your cup-holder or door pockets are very narrow, because it’s exactly the same diameter as a standard soft drink can.
The lid is released by pressing a button, which can be locked with an extra clip to ensure it doesn’t get knocked and leak. There’s no straw so you have to tilt the bottle to drink, but the main let-down is the price. It’s of nice quality, but costs too much compared to the others here.
Buy now from Amazon
Chilly's 500 bottle
If space is tight in your car, then this small bottle from Mountain Warehouse could work well. At 20cm high and 7cm wide, it’s about the same size as a large drinks can. It proved leak-free but has a wide spout rather than a straw, so you need to tilt your head to drink.
A fabric strap makes this bottle easy to hold and handle, but because it’s quite small and has no special features, it looks a little pricey in this company.
Buy now from Mountain Warehouse
Chilly's 500 bottle
This bottle’s unique feature is a built-in ‘infuser’ which lets you drop pieces of fruit into the water to make it taste better. Like the smaller bottle from Mountain Warehouse, this uses a flip lid and a spout rather than a straw.
Although that 500ml version is easy to drink from, this one has an awkward lid that makes it tricky when supping because it gets in the way, especially while driving. It feels a little cheap, too.
Chilly's 500 bottle
This pretty basic bottle is good value (it costs £4 online but we found it for £3 in-store) and holds an impressive 750ml. It’s simple to use, with a nozzle that folds out and can be opened with one hand.
The bottle also remained completely leakproof, even with the nozzle up. But it’s let down by the straw itself, which seems to suck in as much air as water while you are drinking, making it hard (and burpy) work to get refreshed.
Buy now from Morrisons
How we tested them
What’s the law?
Reviews
Chilly’s 500ml
Chilly's 500 bottle
- Price: £20
- Capacity: 500ml
- Rating: 5 stars
Chilly's 500 bottle
- Price: Around £7
- Capacity: 700ml
- Rating: 5 stars
Chilly's 500 bottle
- Price: Around £4
- Capacity: 700ml
- Rating: 4 stars
Buy now from Asda
Chilly's 500 bottle
- Price: Around £16
- Capacity: 600ml
- Rating: 4 stars
Buy now from Amazon
Contigo Matterhorn
Chilly's 500 bottle
- Price: Around £28
- Capacity: 900ml
- Rating: 4 stars
Buy now from Amazon
Chilly's 500 bottle
- Price: Around £11
- Capacity: 591ml
- Rating: 3 stars
Buy now from Amazon
Chilly's 500 bottle
- Price: Around £10
- Capacity: 500ml
- Rating: 3 stars
Buy now from Amazon
Chilly's 500 bottle
- Price: Around £7
- Capacity: 500ml
- Rating: 3 stars
Chilly's 500 bottle
- Price: Around £7
- Capacity: 600ml
- Rating: 2 stars
Chilly's 500 bottle
- Price: Around £4
- Capacity: 750ml
- Rating: 2 stars
