HEAVY DUTY RECIPROCATING AIR BODY CUT OFF SAW + 6 BLADES BODYSHOP CUTTING TOOL | eBa
3" AIR CUT OFF SAW DISC CUTTING GRINDING TOOL Hilka 20,000 rpm 6.2 bar 90 psi | eBa
Bosch GWS 7-115 4.5" Angle Grinder 240v slim grip 115mm 720w 4.5" GWS7115 3165140254670 | eBa
most of us have a angle grinder at home with varied cutting disc's and sanding flap disc's so last year i brought a air cut off disc cutter onlt used twice as limited access due to design but did it's job so was thinking about the reciprocating one for more access
anybody used or have one are they any good?
generic pictures above so also what make would you recommend or just stick with what i have and the good old hacksaw blades ??
