1995 gmc safari non start
Dobby
New member
Hi can any one help it started as a intermittent non start when warm / hot .
I have changed plugs ,ht leads , cap and Rota
Arm I've also changed the icm module and ignition coil as I had no spark .have also checked for voltage to coil and Icm which was all good as is the coil trigger wire , can't find any breaks in the wires from icu to ecu and all this is done with out a wiring diagram
Does anyone have a matching diagram or know anyone who can help with this fault please help guys
Dobby
Hi guys it's me again after more hours spent it the the hot weather I located the problem. The distributor coil winding have corroded causing a open circuit so I fitted a new one I happen to have as a spare so all if fine
Good work, I was feeling it may be fuel delivery but assuming it to be fuel injected could not comment.
This was the corroded part
Good find well done. Now just got to get a replacement. Back on the. Road then :thumb::thumb::thumb:
Awesome, glad you got it sorted. Thanks for posting a photo of what caused the issue. If someone has the same issue and searches there is a good chance this will help someone out.
