1968 Ford Mustang coupe black plate california car with a difference<br />
<br />
Imported from California October 2014 and has been dry stored since. Upon arrival to england the car was running a fuel injected 5.0 small block mated with a Tremec 5 speed manual transmission. After inspection I decided to remove the fuel injection due to how badly it had been fitted and now has been setup on carb.<br />
<br />
Engine spec.<br />
<br />
1993 ford 5.0 from a Fox body converted to run on carburettor setup using all new parts where required<br />
Edelbrock performer intake manifold<br />
Holley 650 cfm 4 barrel carb<br />
Hipo fuel pump<br />
new timing chain set whilst it was stripped<br />
timing cover to suit <br />
Thermostat, heater core, heater hoses, gaskets<br />
MSD distributor kit and coil<br />
Aluminium Radiator with bottom outlet to suit, top and bottom hoses<br />
Kenlowe 13 fan with thermostat control fitted in the top hose<br />
Ford racing valve covers<br />
K & N air filter element and K & N Extreme air filter top<br />
Came to me fitted with Hedman long tube headers into duel flow master exhausts sounds how a mustang should.<br />
<br />
Gearbox and drive line<br />
<br />
Tremec 5 speed manual with all gears as they should be mated to an aluminium prop shaft<br />
rear end is a modern 8.8 posi traction unit complete with disc brakes however unsure on what it has come out of.<br />
Front disc brakes are I believe from a modern ford mustang<br />
Rear leaf springs, bushings and shock absorbers are also fairly new<br />
<br />
Wheels are modern ford 17 five spokes fitted with four as new matching Nankang tyres<br />
<br />
lights have been converted to uk spec with new headlights incorporating side light bulbs and amber indicators all round<br />
<br />
Interior<br />
<br />
Original spec seats all in good condition, nice and neat black head lining <br />
Fitted with new 3 point seat belts<br />
new Hurst shifter and gaitor<br />
New Lockar tunnel mounted hand brake setup which was the best way to hook up with the rear end<br />
<br />
Exterior<br />
<br />
Both doors had bubbling at the bottom corners so have had the corners cut out and new metal welded in<br />
The sills in the past had been fitted with covers and were not with it when it arrived so all the clips have been removed and welded up<br />
front passenger side floor section has been professionally cut out and new sheet metal fully welded in and sealed<br />
Under neath has been treated with underbody seal.<br />
front wings were removed cleaned and painted with 3m shultz along with inner sheet metal<br />
The front lower valance has a dent in it on the passenger side<br />
Body wise it is straight with chips in the paint work and premiered areas as per the pictures<br />
<br />
I purchased the car with a view to it being an on going project and with having a lot of mechanical work done it drives well and starts every time and is useable<br />
<br />
Genuine reason for sale, stupid emails, texts and offers will be ignored. Located in south manchester<br />
Date written: 06-Jun-2016
Price: £14500 As stated
