66 Mustang coupe solid shell age related UK registration<br />
302 v8<br />
New 30 thou plus pistons & rings<br />
New bearings on 10 thou under crankshaft<br />
New oil pump,water pump and fuel pump<br />
New Comp cams performer camshaft<br />
New camshaft bearings<br />
New Comp cams roller rockers<br />
New Comp cams valve springs & retainers<br />
New Comp cams hardened pushrods<br />
New Comp cams adjustable pushrod guide plates<br />
New Comp cams hydraulic lifters<br />
New Cloyes timing chain set<br />
New Cal custom alloy fined sump<br />
New Pro race harmonic balancer<br />
New engine mounts<br />
New finned alloy rocker covers<br />
New Edelbrock air cleaner<br />
Refurbished pair of Windsor Jr big valve cylinder heads<br />
Refurbished Edelbrock performer inlet manifold<br />
New Headman headers<br />
New Magnaflow 2 1/2inch stainless exhaust system<br />
New export & Monte Carlo bars powder coated red<br />
Fuel system<br />
New FiTec Go Efi 4 600HP fuel injection kit<br />
New FiTec fuel commander fuel system<br />
New copper fuel hard lines<br />
New twin fuel filters<br />
Ignition system<br />
New MSD 6AL ignition box<br />
New MSD platinum spark plugs<br />
New MSD spark plug leads<br />
New Mallory HEI distributor<br />
Cooling system<br />
New Mishimoto alloy radiator<br />
New Mr Gasket 16inch electric fan<br />
New Mr Gasket adjustable fan control<br />
New hoses & thermostat<br />
New oil cooler kit<br />
Gear box & Drive line<br />
New T5 V8 mustang five speed gearbox<br />
New heavy duty clutch driven plate<br />
New Modern drive line hydraulic master cylinder kit<br />
New Tilton hydraulic thrust bearing kit<br />
New gearbox cross member & mount<br />
New prop shaft Universal joints<br />
New ring & pinion gear set lowered to 3:25 ratio<br />
New pinion bearings & seals<br />
New Trak Loc limited slip unit<br />
New alloy half shaft retaining plates<br />
Brakes<br />
New SSBC master cylinder & servo<br />
New SSBC 11inch front discs with 4 piston callipers<br />
New rear brake drums with new shoes & cylinders<br />
New hard & flexible lines<br />
Front suspension<br />
New Unisteer rack & pinion conversion<br />
New progressive rate coil springs<br />
New spring perch roller bearing conversion<br />
New Total Control fully adjustable tubular upper control arm<br />
With the one inch Shelby drop incorporated<br />
New Total Control adjustable lower control arm<br />
New Global west adjustable control arm<br />
New Global west tubular stop brace<br />
New Spax shock absorbers<br />
New 1 inch anti roll bar<br />
New anti roll bar poly bush link kit<br />
Rear suspension<br />
New 4/5 leaf springs<br />
New heavy duty shackle kit<br />
New I inch drop kit<br />
New Shelby traction bars<br />
New Spax Shock absorbers<br />
New Whiteline anti roll bar<br />
Wheels & tyres<br />
New Rocket 15inch alloy wheels<br />
New set of BFGoodrich tyres<br />
Electrical system<br />
New American Autowire wiring loom<br />
New battery<br />
New battery tray<br />
New Classic Gauges 1966 Mustang gauge set<br />
New Scott Drake 1966 rally pak with clock & rev counter<br />
New 100 amp single wire alternator<br />
New H4 conversion headlight kit with Osram bulbs<br />
New LED tail light kit<br />
New turn & back up lights<br />
Interior<br />
New carpets<br />
New sun visors<br />
New hump hugger centre console<br />
New seat belts<br />
New TMI rally sport R front & rear seat upholstery with foam<br />
New door & parcel shelf cards<br />
New CJ pony complete rubber & windlass full kit<br />
New grant steering wheel<br />
New Hurst shifter arm & knob plus boot<br />
New heater core<br />
<br />
<br />
<br />
<br />
<br />
The idea was to try and build a classic Mustang and make it reliable and suitable for everyday driving with a bit more performance than standard. So, as you can see all the old and worn components were removed replaced or upgraded making this a 99% new car. This Mustang is very free revving and by far the quickest 302 of all the many Ford small block powered vehicles that I have built and driven. Having said all that, the car will require some finishing off but these are little things that could be done by almost anyone at home as all the main spannering work has been more or less done.<br />
<br />
<br />
The main things remaining to be addressed are front and rear screens are getting a bit milky at the bottom but is still serviceable at the moment. The bonnet and boot lid will require a small repair at the edges the size of a fifty pence piece. body is solid but the paintwork is rough it looks like it has been applied with a yard brush but then you can paint it any colour you want, I was just going to run it for a while in grey primer or matt black while saving for a proper re-spray.<br />
<br />
<br />
This Mustang has had a small fortune spent on new parts fitted to it so far that s not counting the initial purchase price of the base car. It is UK registered with an age-related number. But with a little more investment in paint and some trim it will be a near new Mustang in the end. The one and only reason this Mustang is being offered for sale or trade is because I recently had a major operation to have the big c removed but it seems I can t shake it and after thirty odd years of working on V8 muscle cars, Harleys, rods and the odd armoured car and WW2 military vehicle am now finding things a bit of a struggle now. <br />
<br />
<br />
The reserve is nowhere near to what s been spent on the car and as to any trades or swaps I might be interested in a 50s American car or a nice hotrod maybe something military as long as their light to drive. No more Scammell, s or Diamond T, s for me anymore. Please bear with me and I will get some pictures taken and posted as soon as possible.<br />
<br />
<br />
Date written: 17-Apr-2017
Price: £23000 Or near offer
