An update has been released, we were running V2.1.4. We may not notice much difference, but always good to keep up to date. The update has been applied.
XenForo 2.1.5a Released
XenForo 2.1.5a, the next maintenance release for the XenForo 2.1 series is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo 2.1 upgrade to this release to benefit from increased stability.
If you are already running XenForo 2.1, the easiest way to upgrade is directly from your admin control panel.
Some of the fixes in 2.1.5a include:
- Correctly handle Stripe review callbacks.
- Fix issue with the +/- buttons on number box elements not working in MS Edge browser.
- Add "Spam" button on possible spammers when viewing reports.
- Fix an issue with fixed menu positioning on Safari when scrolling.
- Ensure the import permission helper doesn't fall over when faced with a permission value of 0.
- Update Font Awesome to 5.11 and improve support for duotone icons.
- Back out of a few older iOS workarounds which seem to only be applicable to very old versions of iOS related to inputs within fixed elements in order to fix some issues these cause with iOS 13.
- Ensure favicon / title alert count indicator still displays for counts greater than 999.
- Workaround for displaying future relative timestamps in pages output from the guest page cache.
- Changes to allow certain URLs which do not have a trailing slash to work in a more predictable way.
- Avoid a quirk on the deferred loading rich text editor in Firefox which may insert an empty line when content is first entered.
- Restore the ordering by post_date, post_id as per XF1, so that posts with identical datestamps are ordered sequentially.
- On the discouraged IP list in the Admin CP ensure that the list is properly paginated.
- Update fa-warning to fa-exclamation-triangle in the XF Templater.
- Reduce number of queries on the node moderator lists with a new getFullNodeListCached method.
- Fix logic around user reaction scores when deleting content/changing Reaction scores.
- Prevent false positive detection of duplicate key exceptions in queries due to generic SQL state code.
- Fix timestamp issues after timezone/DST changes.
