If your original keyless entry remote suffers from water damage, corrosion, circuit board failure, a cracked case or other problems, find repair and/or replacement solutions listed under "Electrical" in the RockAuto catalog. Replacement brands and options include:
ACDelco: ACDelco builds GM original equipment remotes. ACDelco remotes range from simple two-button designs (lock and unlock the doors) to the more advanced six-button designs (door lock/unlock, panic button, liftgate/trunk/liftglass buttons, remote start button).
Dorman: Dorman’s keyless entry remotes are as easy to program as they are to use. Professional technicians and special tools are unnecessary. In the event that your remote is simply cracked, Dorman also offers the outer case instead of the entire electronic assembly as an affordable and convenient option. Additional case colors, including green, gray, and pink camouflage, are available for select vehicles.
Standard Motor Products (SMP): SMP's line of TechSmart Keyless Entry Remotes are engineered to be complete OE-style replacements for certain Ford and GM vehicles. They match their OE counterparts in case fit and signal range (all are FCC and IC approved). SMP remotes are easy to program; just follow the relearn instructions in the OE service or owner’s manuals.
Üro Parts: Üro offers new plastic cases, as well as the buttons separately, for European vehicles such as Volvos, Volkswagens and Audis. New buttons are a big help if the symbols on the remote have rubbed off or if the old buttons have ripped or worn out.
And don't forget forum members get a discount code which can be used on as many orders as you like until it expires!
5% Discount Code: C8AB7139ED9A38
Expires: September 5th, 2015
Please enter this code in the ‘How Did You Hear about Us’ box to receive discount. Please note that orders using discount codes must be placed online and the discount code must be entered before an order is submitted to receive the discount. Phone orders are not eligible for discounts.
If you have a question about parts or an order, please visit our FAQ and/or Order Status & Returns page, or send us an email at service@rockauto.com.
