Fitting a 50A Level 2 charger to an older UK garage supply?
I'm Charlotte from Columbus, Ohio, and I drive a 2018 Nissan Leaf that I charge at home. I'm looking at a 50A Level 2 J1772 unit, and I'm trying to work out whether it's worth going that high for my setup. My garage only has an older 60A panel and the run from the house is fairly long, so I'm not sure the wiring would support it without a chunk of extra work. I'm also curious how much the higher amperage actually helps on a Leaf with a smaller onboard charger, versus just adding cost. The third-party info I found lists the usual specs, but it doesn't tell me much about real-world installs in older garages. For anyone who's added a Level 2 charger at home, was the 50A worth it over a lower amperage unit, and did the panel end up being the bottleneck? I'd rather hear from people who've actually dealt with this than guess.
