1966 GMC Chevrolet C10 Pickup For Sale
15331tcac
Call Ellis on 07772451969<br />
Final price reduction to GBP 8500 <br />
<br />
here for sale is our 1966 GMC 1000 (C10) Shortbed Stepside pickup truck. UK registered, running, driving, stopping, headturning goodness. The truck has had lots of work done recently to bring it up to everyday driving standard, with still just a little left to make it 100%. Everything electrical works! Brilliant quirky fun to drive. GMC 250 CUI L6 fitted which runs well and pulls good. 3 speed manual floor shift trans. perfect truck for someone who wants to be able to do some work and make it their own, but DOESNT want to buy one of these complete basket case new imports that needs EVERYTHING going over and replacing to make it road worthy. This is a fun driving truck with bags of character. Easy to lower if you wanted to go that way, flip the axle and chop / get some lowering springs and you"re done. Also being the 250 CUI L6 the trans should fit straight onto a 350. super easy to drop a v8 into this truck. <br />
<br />
New copper brake lines from front to back including front rubber flexi lines and a new rear stainless braided line to the axle. <br />
rear brake cylinders honed and service kits fitted.<br />
All brake adjusters removed greased refitted and adjusted, brakes bled.<br />
Brand new windscreen with top tint, New side glass inc one vent window, and brand new back screen . Front n rear rubber seals new too.<br />
new felt channel fitted in the vertical run of the vent window assemblys for the drop glass, and drivers door window channel.<br />
new bed wood and strips fitted with new coach bolts, very nice scorched effect on wood. <br />
replacement heater blower motor fitted<br />
2x new front wheel bearings<br />
fuel tank removed drained inspected cleaned refitted <br />
LED number plate bolts <br />
new coil <br />
coolant flushed <br />
BRAND NEW ALUMINIUM RADIATOR JUST FITTED with Billet cap<br />
windscreen washer kit fitted (red button on dash)<br />
Amber indicators on rear, headlight switch modified so when dip beam is on amber sides in hood stay on.<br />
carb stripped cleaned and working much better<br />
new choke cable <br />
all front end greased<br />
new aluminium fuel line fitted with new rubber hoses<br />
steering shaft bearing replaced, no up down movement in wheel which seems common in old trucks <br />
points cleaned and set<br />
timing set to 6 BTDC<br />
Oil and filter change<br />
axle oil and transmission oil checked and topped up as required<br />
new wiring to rear for indicators and tail lights<br />
new wiring to front lights <br />
UK spec headlights fitted and relayed & set up on a beam setter <br />
Alternator wiring redone and brush kit fitted in alternator <br />
Pioneer CD stereo with Kenwood 6x9s under the seat<br />
12v socket fitted in dash<br />
new exhaust section fitted <br />
New chrome door mirror and chrome louvered air cleaner fitted.<br />
3 tyres like brand new, dated 2017s I think, one tyre is older but still has full tread. <br />
Date written: 04-Apr-2019
Price: <td><strong>£8500 As stated
