Very pleased with it. The water can be switched from waterfall to fountain at the flick of a switch and the lights (including under water pond lights) are on a photocell so they come on at dusk.
did you do all that yourself???? nice job . be carefull in winter and heavy rain the decking gets very slippery unless you got the new stuff with the grit in the grooves realy good stuff see what type of decking you have
The pond was a kit, excluding planter/waterfall. Everything else self built.
Non grit type decking but that’s ok.... we don’t use unless the sun is out and temp is over 18c!!!
