I think it is time to bleed the brakes. It was done after the engine rebuild back in 2017. I have newish discs and pads which have been bedded in with the correct procedure in the instructions with the discs and pads.
There is a slight imbalance from left to right. The garage offered me a brake bleeded tool. It presurises fluid, you can pump it to what you desire, he recommended 15psi. Then you crack off the bleeded on each caliper individually. The brake pressurising tool also pumps in fluid. This is going to make the job quick and simple.
Probably won't take any longer than it took me to write this email.
I will get photos, I know the rules.
