1966 Ford Mustang coupe with V5C and age related UK registration recently imported from the states.<br />
All the parts listed below as new are brand new and have only done a total of 31 miles on a private area.<br />
Please don t consider this Mustang if you want a ready to go needs nothing doing nice soft run of the mill cruiser that you can jump in and go for a Sunday drive in because this one certainly isn t the one for you. Because of the way its set up it has rattles and squeaks and rides hard but it s a very very quick car that corners like its on rails.<br />
As you can see in the description it has all new parts used in fact the only remaining original parts to the car as it stands now are the body and the rear axle casing.<br />
The new owner would have to be someone who has a good mechanical knowledge and be able to work on and set up this class of cars, when this Mustang was listed last time people were asking me if they could jump in and drive it to London.<br />
The front suspension, steering, carburettor and timing are all fitted to the car more or less straight out of the box and will all require proper aliment and fine tuning. <br />
There are a couple of things remaining to be addressed body wise the front and rear screens are getting a bit milky at the bottom but are still serviceable at the moment. The body is good but will require a couple of small repairs to be addressed.<br />
Also the paintwork is very rough it looks like it has been applied with a yard brush but then you can paint it any colour you want, As the thing is such a brute I was just going to run it as is or in grey primer or matt black until I got around to getting it properly painted.<br />
<br />
This Mustang has had a fortune spent on new parts fitted to it so far making it a quick and good handling car. It is UK registered with an age-related number. But with a little more investment in paint and some trim it will be a near new Mustang in the end.<br />
<br />
The one and only reason this Mustang is being offered for sale or trade is because I recently had a major operation to have the big c removed but it s not going away and after thirty odd years of working on V8 muscle cars, Harleys, rods and the odd armoured car and old military vehicles am now finding things too painful to work on vehicles now.<br />
<br />
Please note there is no buy it now price and requests for the reserve price will be ignored.<br />
<br />
And now the good bits.<br />
<br />
<br />
302 v8 engine<br />
New 30 thou plus pistons & rings<br />
New bearings on 10 thou under crankshaft<br />
New oil pump, water pump and fuel pump<br />
New Ford racing heavy duty oil pump drive shaft<br />
New Comp cams performer camshaft<br />
New camshaft bearings<br />
New Comp cams roller rockers<br />
New Comp cams valve springs & retainers<br />
New Comp cams hardened push rods<br />
New Comp cams adjustable push rod guide plates<br />
New Comp cams hydraulic lifters<br />
New Cloyes timing chain set<br />
New Cal custom alloy fined sump<br />
New Pro race harmonic balancer<br />
New engine mounts<br />
New Ford Racing finned alloy rocker covers<br />
New Edelbrock air cleaner<br />
Refurbished pair of World Series Windsor Junior gas flowed big valve cylinder heads<br />
Refurbished Edelbrock performer inlet manifold<br />
Recent starter motor<br />
New Heddman long headers<br />
New Magnaflow 2 1/2inch stainless exhaust system<br />
New export & Monte Carlo bars powder coated red<br />
New Scott drake hood hinges<br />
New Scott drake steel GT 350 hood scoop<br />
<br />
Fuel system<br />
New Holley street demon 750 cfm carburettor<br />
New copper fuel hard lines<br />
New fuel filter<br />
New tank sender unit<br />
Recent fuel tank<br />
<br />
Ignition system<br />
New MSD 6AL ignition box<br />
New MSD platinum spark plugs<br />
New MSD 8,5mm spark plug leads<br />
New Mallory HEI distributor converted to two wire and fitted with a MSD low resistance coil pick up<br />
<br />
Cooling system<br />
New Mishimoto alloy radiator<br />
New Mr Gasket 16inch electric fan<br />
New Mr Gasket adjustable fan control unit<br />
New hoses & thermostat<br />
New oil cooler kit<br />
<br />
Gear box & Drive line<br />
New T5 V8 mustang five speed gearbox<br />
New heavy duty clutch driven plate<br />
New Modern drive line hydraulic master cylinder kit<br />
New Tilton hydraulic thrust bearing kit<br />
New gearbox cross member & mount<br />
New prop shaft Universal joints<br />
New ring & pinion gear set lowered to 3:25 ratio<br />
New pinion bearings & seals<br />
New Trak Loc limited slip unit<br />
New alloy half shaft retaining plates<br />
<br />
Brakes<br />
New MPB master cylinder & servo<br />
New SSBC 11inch front discs with 4 piston callipers<br />
New rear brake drums with new brake shoes, cables, brake shoe retaining kit & wheel cylinders<br />
New hard & flexible lines<br />
<br />
Front suspension<br />
New Unisteer rack & pinion conversion<br />
New progressive rate coil springs<br />
New spring perch roller bearing conversion<br />
New Total Control fully adjustable tubular upper control arm<br />
With the one inch Shelby drop incorporated<br />
New Total Control adjustable lower control arm<br />
New Global west adjustable strut arm<br />
New Global west tubular stop brace<br />
New Spax shock absorbers<br />
New Shelby 1 inch anti roll bar<br />
New anti roll bar poly bush link kit<br />
<br />
Rear suspension<br />
New 4/5 leaf springs<br />
New heavy duty shackle kit<br />
New I inch drop kit<br />
New Shelby under axle traction bars<br />
New Spax Shock absorbers<br />
New Whiteline anti roll bar<br />
<br />
Wheels & tyres<br />
New Rocket 15inch five spoke alloy wheels<br />
New set of BFGoodrich tyres<br />
<br />
Electrical system<br />
New American Autowire wiring loom<br />
New battery<br />
New battery tray<br />
New Classic Gauges 1966 Mustang gauge set<br />
New Scott Drake 1966 rally pak with clock & rev counter<br />
New 100 amp single wire alternator<br />
New H4 conversion headlight kit with Osram bulbs<br />
New LED tail light kit<br />
New turn & back up lights<br />
<br />
Interior<br />
New carpets<br />
New Restosound radio with mp3 Mustang stereo<br />
New Restosound kick panels with built in speakers<br />
New trunk liner set<br />
New glove box<br />
New sun visors<br />
New hump hugger centre console<br />
New front & rear seat belts<br />
New TMI door & parcel shelf cards<br />
New CJ pony complete rubber & windlass full kit<br />
New grant steering wheel<br />
New Hurst shifter arm & knob plus boot<br />
New heater core<br />
New heater Scott drake plenum chamber<br />
New demister ducts & hoses<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Date written: 12-Jul-2017
Price: £23000 Or near offer
